reldisp
The relative displacement (reldisp) math function allows you to transform vector results from time history or animation result files according to a coordinate system defined by three nodes from the same result file.
reldisp(x_vector, dummy_param, node_ID_origin, node_ID_xdir, node_ID_xyplane, node_ID_trans, transformed_value, coord_system)
reldisp(p1w3c1.x,0,198,252,251,2968,"x","OXY")
Argument
x_vector
Independent vector (x vector) which must be the time vector of the type file. This must be an absolute math reference like "p1w1c1.x". If a non-supported file type is provided, an error is displayed in the message log. The subcase is read from the subcase of the time vector referred to by this argument.
dummy_param
Dummy parameter for future use; set to 0.
Arguments 3-5 define the IDs of the coordinate systems.
Note: Only the node ID has to be given for arguments 3-6.
node_ID_origin
The node for the coordinate system's origin.
node_ID_xdir
The node ID for the x direction.
node_ID_xyplane
The node ID for the xy plane.
node_ID_trans
The node ID for which the results will be transformed.
transformed_value
Defines which value is returned for the transformed node.
Valid arguments are: "x", "y", "z" or "mag".
coord_system
Defines the coordinate system according to HyperView (default = "OXY"). Possible values are "OXY", "OYZ" or "OZX".
This allows you to see the relative displacements in the higher sampling rate normally provided by time history results.
The function supports PAM-CRASH (*.thp, *.dsy), LS-DYNA (*.d3plot, *.nodout, *.binout), and Radioss (*.thp) files.
Note: The result file must contain the node positions in the global coordinate system for each time step, or in model data (positions for time step 0) and displacements. If no positions are in the result file, an error is displayed in the message log.
