logint
Logarithmic interpolation function.
logint(old_x, old_y, new_x, flag)
Argument
old_x
The x vector of the curve to be interpolated.
old_y
The y vector of the curve to be interpolated.
new_x
A scalar or a vector containing x values for which new y values are to be calculated.
flag
0 - results in both axes being logarithmically scaled.
1 - only X axis is being logarithmically scaled.
2 - only Y axis is being logarithmically scaled.
Flag 0 results in both axes ben logarithmically scaled.
Flag 1 works if only one X axis is logarithmically scale. The Y axis is linearly scale.
Flag 2 works if only one Y axis is logarithmically scaled. The X axis is linearly scale.
Figure 3.
Curve Math Vectors Results
x = new_x
y = logint(c1.x, c1.y, new_x)
Given c1, a curve is created with interpolated y values at each point of new_x.
The logint function uses linear interpolation to resample data. logint estimates a y-value for each element in new_x such that the new points lie on or near the curve defined by old_x, old_y. old_x, old_y and new_x must have the same number of elements.
If old_x is not entirely increasing and new_x is a scalar, the first value of old_x is used. If new_x is a vector, old_x must be entirely increasing.
If new_x is a scalar, the result is a scalar. If new_x is a vector, the result is a vector with the same number of elements as new_x.
logint performs interpolation only. All values of new_x must lie between the minimum of old_x and the maximum of old_x.
