projectcurvetosurface
Projects a curve onto a surface or waterfall plot and returns the specified channel’s values of the projection in the specified direction.
projectcurvetosurface(curve_x, curve_y, curve_z, surface_x, surface_y, surface_z, channel, dir)
Argument
curve_x
The X value of curve.
curve_y
The Y value of curve.
curve_z
The Z value of curve.
surface_x
The X value of surface or waterfall.
surface_y
The Y value of surface or waterfall.
surface_z
The Z value of surface or waterfall.
channel
The channel (can be x, y, z, or w).
dir
The direction (can be x, y, or z).
Template
{projectcurvetosurface(p2w1g1c1.x,p2w1g1c1.y,p2w1g1c1.z,p2w1w1.x,p2w1w1.y,p2w1w1.z,”y”,”z”)}
{projectcurvetosurface(p2w1g1c1.x,p2w1g1c1.y,p2w1g1c1.z,p2w1w1.x,p2w1w1.y,p2w1w1.z,”Z”,”z”)}
