xy select
Select a file set or subset.
xy select fileset <name>=<value>
xy select subcaseset <name>=<value>
Arguments
fileset
The name of the file set to plot. Define the options below:
curveattributes=<attributetype>
Select from file, standard, or layout.
curveattributes=standard
directory=<directory>
directory="c:/temp/Multiple_Files/doe_1"
filelist=<relative_file_path_list>
Define the file path.
filelist="run__00001/m_1/boxbeam_0001.out","run__00001/m_1/boxbeam_0002.out","run__00001/m_1/boxbeam_0004.out"
labelprefixsuffix=<label>
Define a label.
labelprefixsuffix=path
typeprefixsuffix=<prefix/suffix>
Select prefix or suffix.
typeprefixsuffix=prefix
subcaseset
The name of the subcase set to plot. Define the options below:
file=<filename>
Select a file from the file browser.
attach=<attachmode>
The attachment type. Options include:
  • none (attach=none_
  • attachxvectorsonly (attach=xvectoronly)
  • attachxandyvectors (attach=attachxandyvectors
subcaselist=<subcase_label_list>
Select all, or a range of subcases.
subcaselist=all
subcaselist="Subcase_1"-"Subcase_4","Subcase_8"
subcaselist=1-2,4
subcasenameas=<true/false>
Select true or false.
subcasenameas=false
xy select fileset= "File Selection 1" directory= "C:/<installation_directory>/tutorials/mv_hv_hg/plotting/MultipleFiles" typeprefixsuffix= suffix labelprefixsuffix= none curveattributes= byfile ignorestrings= none filelist= run__00001/m_1/boxbeamT01 , run__00002/m_1/boxbeamT01
