result vector load
Loads and plots the vector data type.
result vector load <name> <name1>=<value1>
Arguments
<name>
The name of the vector to edit.
<name>=<value>
The name=value data name and/or attribute pairs that define the relevant data for the plot. For attributes, this can be either the attribute name or ID.
cornerdata=<true/false>
If corner data is available, enter true to use the Use corner data option, which displays color bands by interpolating available corner results within each element.
layer=<layer>
The layer definition.
layerfilter=<layerfilter id/layerfilter label?>
Enter the filter ID and value to reduce the layer list.
marked = <true/false>
Enable/disabled marked elements.
sset = <sset name>
Enter a selection set name.
system=<analysis/global/elemental/system name>
Enter the coordinate system that will be used to plot the results.
type =<typel>
The result type.
usetracking=<true/false>
If a tracking system has been activated in the Tracking panel, enter true to transform and resolve the results in the activated tracking system.
result vector load type="Acceleration" system=analysis
result vector load type="Stress"
