result vector legendmax
Defines the legend's maximum value.
result vector legendmax <value>
Arguments
- <value>
- Enter the legend's maximum value.
result vector legendmax 14
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
ClassicCreate and manage the contour plot.
Makes a subcase current.
ClassicCreate and manage tensor plots.
ClassicCreate and manage vector plots.
ClassicClears the vector plot.
Changes the vector color for the components or resultant by direction or value.
Changes the value display.
Clears the vector plot from the modeling window.
Edits the vector plot legend properties.
Enables the legend's maximum value.
Defines the legend's minimum value.
Enables the legend's minimum value.
Loads and plots the vector data type.
The multiplier for scaling all the result values.
Vector plot section options.
Displays the current vector plot in the modeling window.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
View manipulation.
Perform actions on XY files.
Result loading.
