result tensor legendmax
Defines the legend's maximum value.
result tensor legendmax <value>
Arguments
- <value>
- Enter the legend's maximum value.
result tensor legendmax 14
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Upfront Data LoaderLoad and unload animations.
Upfront Data LoaderCancels all currently loading results.
Upfront Data LoaderCreate and manage contour plots.
Makes a subcase current.
Upfront Data LoaderCreate and manage tensor plots.
Upfront Data LoaderClears the tensor plot and returns the model to its original state.
Changes the tensor color by direction.
Upfront Data LoaderCreates a tensor data type.
Upfront Data LoaderDeletes tensors from the model.
Changes the value display.
Upfront Data LoaderEdits the tensor data type.
Clears the tensor plot from the graphics window.
Edits the tensor plot legend properties.
Enables the legend's maximum value.
Defines the legend's minimum value.
Enables the legend's minimum value.
Upfront Data LoaderLoads the tensor data type.
The multiplier for scaling the result values.
Upfront Data LoaderPlots the tensor data type results.
Upfront Data LoaderRenames the tensor definition.
Displays the current tensor plot in the modeling window.
Upfront Data LoaderUnloads a tensor data type.
Upfront Data LoaderUpdates the tensor plot.
Upfront Data LoaderCreate and manage vector plots.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
View manipulation.
Perform actions on XY files.
Result loading.
