attribute sset
Sets selection set attributes.
attribute sset drawsize <integer> <all/name>
attribute sset drawstyle point|shaded|sphere|wire <all/name>
attribute sset visibility <true/false> <all/name>
Arguments
drawsize
Enter a value to change the thickness of the wire or the size of the point/sphere drawing for the active set.
all or <name>
Select all to apply the draw size to all sets.
Select or enter a specific set name to apply the action only to that set.
drawstyle
Sets the drawing style for the active set.
point
Draw as a point. Draws the nodes in the set using 2D pixels (for Node sets only).
shaded
Draw as shaded. Shades the components in the active set the color currently displayed in the Color box (for Component sets only).
sphere
Draw as a sphere. Draws the nodes in the set using 3D pixels (for Node sets only).
wire
Draw as a wire. Draws a wireframe on the elements or components in the active set (for Component and Element sets only).
all or <name>
Select all to apply the draw style to all sets.
Select or enter a specific set name to apply the action to only that set.
visibility
Change the selection set's visibility.
true
Makes the selection set visible.
false
Hides the selection set from view.
all or <name>
Select all to apply the visibility type to all sets.
Examples
Set the drawsize for all selection sets:
attribute sset drawsize 5 all
Set the drawsize for only a selection set Set_50:
attribute sset drawsize 5 Set_50
Draw style examples:
attribute sset drawstyle point Set_16
attribute sset drawstyle shaded Set_11
attribute sset drawstyle sphere Set_15
attribute sset drawstyle sphere all
attribute sset drawstyle wire Set_50
Set the selection set's visibility to true:
attribute sset visibility true Set_1
attribute sset visibility true "2D Set"
