annotation note
Creates, deletes, and edits notes.
annotation note create <name>
annotation note delete all
annotation note delete <name>
annotation note <name> attach <name1>=<value1>
annotation note <name> display <name1>=<value1>
annotation note rename <name> <new label>
Arguments
create
Create a note.
<name>
Enter a name for the note.
delete
Delete a note.
all
Delete all notes.
<name>
Select from the list or enter the name of the note to delete.
<name> attach
The note attachment type. <name> is the note's name. Attachment types include coordinate, entity, and window.
coordinates
Attach the note to the XYZ coordinates.
x=<x>, y=<y>, z=<z> Enter the x, y, and z coordinates of the note.
entity
Attach the note to an entity. Select one of the following entity types: component|element|node|system.
<id> Enter the entity ID.
select Select an entity from the modeling window.
window
Attach a note to the window.
x=<x>, y=<y> Enter normalized x and y screen coordinates between 0-1.
<name> display
Note display settings. Options include:
aligntext=<left/center/right>
Aligns the note text.
autohide=<true/false>
Hide the note box when the entity that the note is attached to is not visible on the screen.
bordercolor="<R> <G> <B>"
bordercolor=<color>
Select a color for the note box border. Enter RGB values, select <color> to display and select a color from the color palette, or select a color from the list.
borderthickness=<0-4>
Select a border thickness value to apply to the note box. Enter a value between 1-4.
fillcolor="<R> <G> <B>"
fillcolor=<color>
Select a fill color for the note. Enter RGB values, select <color> to display and select a color from the color palette, or select a color from the list.
Note: This is deactivated if filltransparency=true.
filltransparency=<true/false>
Removes the color from within the note box and makes it transparent against the window.
font=<font>
Select the font type.
fontsize=<fontsize>
Select the font size. Enter a value between 8-48.
movetoentity=<true/false>
Positions the note at the attachment location. This option is disabled if Window is selected as the attachment type.
screenanchor=<true/false>
The note remains stationary during animation or when manipulating the model view. This option is disabled if Window is selected as the attachment type.
shape=<rectangle,circle,ellipse>
Select the shape of the note box.
text=<text>
Enter note text.
textcolor="<R> <G> <B>"
textcolor=<color>
Select a color for the note text. Enter RGB values, select <color> to display and select a color from the color palette, or select a color from the list.
visibility=<true/false>
Display or hide the note from the modeling window.
x=<x>
The x coordinate of the note's location in the modeling window.
y=<y>
The y coordinate of the note's location in the modeling window.
rename
Rename a note.
<name>
Select the name of the note you want to rename.
<name>
Enter the note's new name.
Examples
Create a note:
annotation note create Note1
Delete all notes:
Delete Note 2:
annotation note delete "Note 2"
Attach a note to coordinates, an entity, or a window location:
annotation note "Note 5" attach coordinates x=0.5 y=0.5 z=0.5
annotation note "Note 4" attach entity component id "1 Solid 19"
annotation note "Note 3" attach window x=0.5 y=0.5
Rename a note:
annotation note rename Note1 Note2
Change the note's visibility:
annotation note "Note 1" display visibility=false
Define the note's x and y coordinates for display:
annotation note "Note 1" display x=3
annotation note "Note 1" display y=3
Define the note's text color:
annotation note "Note 1" display textcolor=Red
Define the note's text:
annotation note "Note 1" display text="Note 1"
Align note text:
annotation note "Note 2" display aligntext=Center
Hide the note box:
annotation note "Note 2" display autohide=true
Define the note box border color:
annotation note "Note 1" display bordercolor="255 255 255"
Define the note box border thickness:
annotation note "Note 3" display borderthickness=3
Define the fill color for the note:
annotation note "Note 3" display fillcolor="44 85 126"
Define the transparency of the note box:
annotation note "Note 2" display filltransparency=false
Define the font and font size:
annotation note "Note 2" font="Papyrus 10 normal roman"
annotation note "Note 2" display fontsize=12
Define the note's position:
annotation note "Note 2" display movetoentity=true
Define the screen anchor parameter:
annotation note "Note 2" display screenanchor=true
Define the shape of the note box:
annotation note "Note 2" display shape=ellipse
