HMRES_valueadd()
Adds a value to the current open data type.
int HMRES_valueadd(HM_entityidtype id, double value);
HyperMesh hmreslib Function
id
The ID of the node or element that should be assigned the value.
value
The value to be assigned to the node or element.
Zero, if successful; otherwise, nonzero.
Before a value can be stored in the results database, a simulation and data type must be opened.
None.
