HMRES_complexvalueadd()
Adds a complex value to a data type.
int HMRES_complexvalueadd(HM_entityidtype id, double magnitude, double phase);
HyperMesh hmreslib Function
id
The ID of the node or element.
magnitude
The magnitude component of the complex number.
phase
The phase component of the complex number in degrees.
None.
