HMRES_complexdisplacementadd()
Adds a complex number displacement to a data type.
int HMRES_complexdisplacementadd(HM_entityidtype id, double xmag, doubleymag, double zmag, double xphase, double yphase, double zphase);
HyperMesh hmreslib Function
id
The ID of the node.
xmag
The magnitude of the x coordinate of displacement.
ymag
The magnitude of the y coordinate of displacement.
zmag
The magnitude of the z coordinate of displacement.
xphase
The phase of the x coordinate of displacement in degrees.
yphase
The phase of the y coordinate of displacement in degrees.
zphase
The phase of the z coordinate of displacement in degrees.
None.
