HMRES_SetOutputFilename()
Sets the initial name of the res file name.
void HMRES_SetOutputFilename(char *outputfilename)
HyperMesh hmreslib Function
outputfilename
The filename to set as the res filename.
This must be called before HMRES_SetNewOutputFilename. For use with HMRES_ResFileSizeLimitReached, HMRES_UpdateToNewOutputFilename, and HMRES_SetFileSizeLimit.
None.
