HMRES_openinputfile()
Opens an input file containing results.
FILE * HMRES_openinputfile(char * filename, char * mode);
HyperMesh hmreslib Function
filename
The name of the results file to be opened.
mode
The type of file to be opened. Use:
rb If the file is a binary file.
rt If the file is a text file.
This function can take the arguments passed in by you and open standard input as its input stream, if a file name is not specified.
None.
