HMRES_initialize()
Initializes hmreslib.
void HMRES_initialize(int numindatatype);
HyperMesh hmreslib Function
numindatatype
The number of entities that are expected to be stored in a data type. Setting this value to zero uses the default value of 500.
This function must be called before any other function in the hmreslib package.
None.
