HMIN_setviewangles()
Sets the view to the desired angle as read in the translator.
HMIN_setviewangles(THETAX,THETAY,THETAZ)
HyperMesh hminlib Function
THETAX
The angle in degrees.
THETAY
THETAZ
As attributes are created, they are assigned a specific solver number, 0 through 127. When you write a deck for a specific solver, the template system only uses attributes that match the solver number specified in the template with the *codename()command. Templates distributed with HyperMesh use solver numbers 0 through 63. Altair customers use solver numbers 64 through 127. Call HMIN_setsolver() after HMIN_init() if attributes are being used.
None.
