HMIN_set_unsupportedfile_extension()
Sets the file extension for the unsupported data log file.
void HMIN_set_unsupported_extension(char *extension);
HyperMesh hminlib Function
If not specified, the default value of hmx is used.
This command must be used before the HMIN_extratext() command.
extension
The file extension without the dot separator.
To set the extension based on an initial condition type:
if (!stricmp(string, "INITIAL_STRESS"))
    HMIN_set_unsupportedfile_extension("abc"); //set file with .abc extension
    HMIN_extratext(0, bufferstring, 0);        //write bufferstring to file with .abc extension
if (!stricmp(string, "INITIAL_STRAIN"))
    HMIN_set_unsupportedfile_extension("lmn"); //set file with .lmn extension
    HMIN_extratext(0, bufferstring, 0);        //write bufferstring to file with .lmn extension
None.
Version History
12.0
