HMIN_move_writeid()
Moves the entity identified by ID to the new location.
void HMIN_move_writeid(HM_entityidtype id);
HyperMesh hminlib Function
id
The ID of the element.
HMIN_move_write() must be called first to indicate the name of the collector where the entity should be moved.
None.
