HMIN_maximumids_initialize()
Initializes the maximum ID.
void HMIN_maximumids_initialize(void);
HyperMesh hminlib Function
None.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Retrieves the value of the current maximum ID.
Retrieves the next ID and adds 1 to the maximum ID.
Resets the maximum ID to zero.
Assigns a maximum ID to the entities.
None.
