Save Files
Saves a session, model or document file.
  1. Save an existing file in the following ways:
    Note:
    Options may be disabled, depending on the application you are using.
    • From the menu bar, click File > Save > <file type> to save the current model under its current name, updating/overwriting its older version each time you save.
    • From the menu bar, click File > Save As > <file type> to save the current model under a new file name and/or directory.
    • From the Standard toolbar, click the drop-down next to the Save icon and select a file type from the list.
  2. If the file has not been saved before or if you selected Save As, the Save As dialog opens. Enter a name for the file and save it to your working directory.
