Delete Channels, Events, and Subcases
Remove options from the Load Map dialog.
  1. Click the Load Map tool.
    The Load Map dialog opens.
  2. On the top half of the dialog, select a load channel and click to delete it.
  3. On the bottom half of the dialog, select an event or a subcase associated with an event and click to delete it.
