Add a Parameter to the Plot Macro Parameter List
  1. From the Plot Macros panel, click Add.
    The Edit Plot Macros dialog is displayed.
  2. Click the Parameters tab.
  3. Click Add.
  4. Enter a name in the Parameter text box.
  5. Press ENTER or click in another box.
    The new parameter name is displayed in the list.
  6. Enter a variable name in the Varname text box.
  7. Select Scalar or Curve from the combo box.
  8. Click Close.
    The new parameter is listed in the Parameters list on the Plot Macros panel.
    Note: Select the option Hide input curves by default to set the default state of the Hide input curves check box on the Plot Macros panel when you select a macro from the Macro list.
