Add a Curve to a Plot Macro
  1. From the Plot Macros panel, click Add.
    The Edit Plot Macros dialog is displayed.
  2. Click the Curve tab.
  3. Activate the Create curve check box.
  4. Enter a label for the curve in the Label text box.
  5. Enter X and Y coordinates.
  6. If you are plotting complex data, specify the Y expression in Real/Imaginary or Phase/Magnitude.
  7. Click Close.
