Connect a Note to a Specific Point on a Plot
  1. From the Notes panel, click the Attach To tab.
  2. Select Coordinates as the attachment method.
  3. Enter the x coordinate in the X coordinate text box.
  4. Enter the y coordinate in the Y coordinate text box.
  5. For complex plots only, select Attach to real or Attach to imaginary.
Or
  1. Press Shift and click on a curve to enter the x and y coordinates of the nearest point on the curve.
  2. Press Ctrl and click on a curve point above the median to enter the x and y coordinates for the maximum of the curve.
  3. Press Ctrl and click on a curve point below the median to enter the x and y coordinates for the minimum of the curve.
  4. Click Apply.
