Add a Note
  1. From the Notes panel, click Add under the Note list.
    A note labeled Note1 is appended to the list.
  2. Select the new note from the list and enter a note name in the field above the list and press Enter.
    The new note is now displayed in the list using the new name.
  3. Enter note text in the text box.
  4. Click Apply.
  5. Select an alignment.
  6. Select an attachment method.
    The new note is now displayed in the window.
