Enable/Change Curve Units Dialog
From the Enable/Change Curve Units dialog, you can change the unit type and measurement of a curve.
  1. To view the dialog, select a curve, right-click and select Enable/Change Curve Units.
  2. For the X Vector and Y Vector, select a new unit type from the drop-down menus. To disable a units for a vector, select None.
