Add an Axis to an XY Plot
  1. From the Axis option menu, select either Horizontal or Vertical.
  2. Click Add.
    An axis named "X1" or "Y1" is added to the axis list and a new axis is displayed in the HyperGraph window. Horizontal axes are added to the top of the plot. Vertical axes are added to the right side of the plot.
  3. Enter a name for the new axis in the Axis text field and press Enter.
    The name appears in the axis list.
  4. On the Text tab, enter a label for the new axis in the Label text field.
    The label is displayed alongside the new axis in the HyperGraph window.
