Copy and Paste a Datum Line
  1. From the Datum Lines panel, select a datum line from the datum list or from the screen.
  2. Click Copy.
  3. Go to the page where you want to paste a copy of the datum line and click on a plot.
  4. Select Horizontal or Vertical.
    For polar plots, select Phase or Radial instead of Horizontal or Vertical.
  5. Click Paste.
    A copy of the datum line is added to the datum list.
    The status of the Datum check box is retained when a datum line is copied.
