Activate or Deactivate a Datum Line
  1. From the Datum Lines panel, select a datum line from the Datum list or from the screen.
    When the Datum check box is activated, the datum line is displayed. This is on by default.
  2. Deactivate the Datum check box to hide the datum line.
