Coordinate Info
Retrieve individual point data on any curve in the active window. When a point is selected, the point data is displayed on the panel.
When a point is selected, the point data is displayed on the panel. There are three ways to retrieve point data from a curve. A point can be picked from a curve, located using the Find Point controls, or selected from the point list.
Find Point Controls
The range boundaries can also be picked using the Find point controls.
Click
To Find
the left-most or right-most end point.
the next point to the left or right.
global maximum of the curve.
the next local maximum to the left or right.
the global minimum of the curve.
the next local minimum to the left or right.
Next Curve
the corresponding point on the next curve.
Point List
The point list displays the XY data points for the selected curve. The point number, the X-value, and the Y-value for each point is displayed in the list. Use the scroll bars to view the entire list. Click on a point in the list to display the point data.
Point Data
The following data is displayed when a point is picked:
Curve
The name of the curve.
Point
The number of the data point.
X
The X value of the data point.
Y
The Y value of the data point.
Slope
An estimate of the slope of the curve at the selected point.
Time
The timestep of the data point (if available).
Displaying Point Data
Under Show X as and Show Y as, you can choose from the following options to display the point data:
  • Linear
  • db10, to display data in decibels
  • db20, to display data in decibels
Select Sync Coordinate Data with Axis Format to show coordinate info curve values in the same format (scientific, fixed) as used by the axis. See the Axes panel for more information on defining the axes.
