Define a Range
Specify a range of values for a vector.
  1. Click Range to display the Range dialog.
  2. Enter the start and end points for the range of values in the From and To fields, respectively.
  3. In the By field, enter an increment by which the values in the range are created.
  4. In the Vector field, the range is denoted using the following syntax: from:to:by
  5. Or, enter the information directly into the Expression field using the same syntax.
  6. Click OK to insert the range in the vector field.
  7. Click Cancel to exit the Range dialog without inserting the range into the expression.
