The beam cross section is always defined in a y,z plane.
The x-axis is defined along the beam axis. The coordinate system you define is called
the local coordinate system; the system parallel to the local coordinate system with
the origin in the centroid is called the centroidal coordinate system; the system
referring to the principal bending axes is called the principal coordinate
system.
For shell sections, only the theory of thin walled bars is used. This means that for
the calculation of the moments and product of inertia, terms of higher order of the
shell thickness t are neglected. Thickness warping is also neglected.
- Area
A=∫dA
- Area Moments of Inertia
Iyy=∫z2dA
Izz=∫y2dA
- Area Products of Inertia
Izz=∫y2dA
- Radius of Gyration
Rg=√IminA
- Elastic Section Modulus
Ey=Iyyzmax
Ez=Izzymax
- Max Coordinate Extension
ymax=max|y|
zmax=max|z|
- Plastic Section Modulus
Py∫|z|dA
Pz∫|y|dA
- Torsional Constant
- Solid
It=Iyy+Izz+∫(z∂ω∂y−y∂ω∂z)dA
- ω - Warping function
- (see below for warping function)
- Shell open
It=13∫t3ds
- t - Shell thickness
- Shell closed
It=2∑AmiFsi
Ami
- Area enclosed by cell
i
Fsi
- Shear flow in cell
i
- Elastic Torsion Modulus
- Solid
Et=Itmax(y2+z2+z∂ω∂y−y∂ω∂z)
- Shell open
Et=Itmaxt
- Shell closed
Et=Itmax(Fsit)
- Shear Center
ys=IyzIyω−IzzIzωIyyIzz−I2yzIyω=∫yωdA,Izω=∫zωdA
zs=IyzIyω−IyzIzωIyyIzz−I2yz
- Warping Constant (normalized to the shear center)
Iωω=∫ω2dA
- Shear deformation coefficients
αzz=1Q2y∫(τ2xy∣∣Qz=0+τ2xz∣∣Qz=0)dA
αzy=1QyQz∫(τxy∣∣Qy=0τxy∣∣Qz=0+τxz∣∣Qy=0τxy∣∣Qz=0)dA
αzz=1Q2z∫(τ2xy∣∣Qy=0+τ2xz∣∣Qy=0)dA
- Shear stiffness factors
kyy=1αzz
kyz=−1αyz
kzz=1αyy
- Shear stiffness
Sii=kiiGA
- Warping Function
∇2ω=0
(∂ω∂y−z)ny+(∂ω∂z+y)nz=0
- For solid sections, the warping function is computed using a finite
element formulation. This may lead to un-physically high stresses in
geometric singularities (sharp corners) that get worse with mesh
refinement. This may cause problems computing the elastic torsion
modulus.
Nastran Type Notation
/1=Izz
/2=Iyy
/12=Iyz
K1=Kyy
K2=Kzz
