Macros
Access pre-defined macros packaged with the NVH solution and also user-defined macros.
To open this tool, from the menu bar, click Tools > NVH Macros when the NVH user profile is loaded.
Pre-defined macros are available in the Predefined tab. User-defined macros can be added/removed in the Userdefined tab.
Add and delete options are available in the right-click context menu. The selected macro fetches the design variables from the model property database and exports them to the FE input solver deck.
