HyperWorksEngineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver
technology.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with
a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing
tasks efficiently.
The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of
multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop
height in a typical drop test by controlling the run parameters and conditions with ease.
In the Manage Model section of the Drop Test Manager, the Import/Create task allows you to choose whether or not the
fluid inclusion is needed for the drop test simulation.
Drop Test has the following general geometry capabilities: Import geometry from an external CAD file, export geometry
to an external CAD file, create new geometry, edit and defeature existing or imported geometry, create connectors
on geometry, create loads/BCs on geometry, and create meshes on geometry.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
The Materials and Properties panel allows you to quickly create or edit a material or
a property and assign it accordingly. Alternatively, you can visualize and select a
material from the database, or customize and add materials into the database.
Contacts
Default contacts that are required for the drop test are automatically created by the
Drop Test Manager. Default contacts created by the utility cannot be modified.
