Install and Invocate the Drop Test Template
In order to install/invoke on a PC, follow the below procedure:
- Download the utility.
- Create a folder on any local drive. This will be the template working directory.
- Unzip the file using any of the zip utilities available.
Select an option where you see the following items under the main folder under
the template working directory:
- A folder called tclincludes
- A folder called utils
- A folder called modules
- A folder called images
- A file named drop_test.pmd
- A file named drop_test.pmt
- Start a new HyperMesh session with the Radioss user profile.
- Click .
- Under the Process Manager utility, click browse and select the file drop_test.pmt to invoke the drop test process template.
