PLOAD1 Create and Review
Create and review pressure loads on 1D elements that are fully or partially loaded.
From the menu bar, click .
This tool can also be used to edit or review the PLOAD1 cards imported from a solved Nastran or OptiStruct data file.
Inputs are 1D elements and the start/finish local parametric values and the pressure at those points (start and end pressures).
