Field Looper
Use multiple combinations of source files (in the form of CSV) and multiple target models (decks or HyperMesh .dbs) to realize field mapping for the creation of new loads, such as temperature and pressure.
Field Looper works in full batch mode and the setup of the mapping is done through a dedicated graphical user interface table. The setup can be saved and retrieved through a .csv file.
  1. From the menu bar, click Aerospace > Loads/BCs > Field Looper.
  2. Add rows.
  3. Select .csv files as sources.
  4. Select target files.
    These can be HyperMesh database names (loadcases will be created) or a Nastran input file name.
  5. Click Apply.
