HMNAME COMP
Import comment to sort and organize entity types into HyperMesh.
HMNAME COMP id, name, property_id, property_name, id_pool
HyperMesh Comments
Input
entity_type
COMP
id
Unique entity type identification number.
name
A name given by you to help organize the model or describe the entity.
property_id
Unique entity type identification number. Valid only for OptiStruct and Nastran.
property_name
A name given by you to help describe the entity. Valid only for OptiStruct and Nastran.
id_pool
Internal solver ID pool. Valid only for OptiStruct and Nastran.
Supported Solvers
OptiStruct
Radioss
ANSYS
LS-DYNA
Nastran
