HMASSEM_COMP_ID
Import comment to sort and organize entity types into HyperMesh.
HMASSEM_COMP_ID compid(s)
HyperMesh Comments
Input
- compid(s)
- A list of identification numbers.
Supported Solvers
Abaqus
Nastran
PAM-CRASH 2G
View new features for Engineering Solutions 2021.
HyperWorks Engineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver technology.
Explore the Engineering Solutions user interface.
The title bar displays the name of the file that is currently opened, along with the active product and user profile.
The menu bar contains pull-down menus that provide access to standard functions such as file management operations, system preferences, and help.
Each toolbar contains a group of icon buttons that provide access to common tools.
The tab area organizes browsers, Utility menus for the solver interfacing user profiles, and other functionality not shown in the panel area in different tabs.
The modeling window displays your model, geometry and plots.
Quickly find and open the tools, panels, and browsers that are available from the menu bar pull-downs or from the Utility Browser, as well as create solver cards.
The status bar displays information pertaining to the currently loaded model as well as descriptions of the pages and panels.
Undo and redo actions performed in Engineering Solutions.
Use the Visualization controls to change many of the visual states in Engineering Solutions and HyperView.
Input controls allow you to manipulate your methods of entering and controlling different aspects of Engineering Solutions.
Engineering Solutions requires the use of different types of data files, from its own database files which contain data on model geometry, mesh, loads, boundary conditions, and so on, to property cards, main weld files and many more.
Engineering Solutions uses the proprietary (.hm) format for database files which include geometry, meshing, connectors, loads and forces, materials, and everything else that is necessary to pre-process a model prior to sending itto a solver.
BINARY database files are the primary files used by Engineering Solutions and use the file extension .hm.
In Engineering Solutions various file types can be imported into the selected client. The Import tab allows you to input external CAD line and surface data or finite element models. You can also import/merge model files (.hm) into the current model session.
In Engineering Solutions exporting various file types from the selected client to another format. The Export tab allows you to export a model to CAD line and surface data or finite element models.
Export a CAD file.
Export model files.
If you insert special comment cards into your input deck, you can provide HyperMesh with additional information about the colors and names of entities. You can also use comments to preserve information that is not supported by a particular solver, for example, assemblies or system references.
Associate an existing node to an existing surface.
Import comment to sort and organize property types and info into HyperMesh.
Import comment that indicates the beginning of the model documentation into HyperMesh.
Continuation card for the HMBEAMSEC card.
Preserves the style information for load curves.
Points to a material database file for the solver.
Defines the base location of a velocity load in HyperMesh.
Import comment to sort and organize design properties into HyperMesh.
Import comment that indicates the end of the model documentation into HyperMesh.
Preserves the ADMASS card upon import in Radioss.
Export comment that detects a problem upon export.
Describes weld points for the automesher.
Import comment that indicates the beginning of the footer for the deck.
Import comment that indicates the end of the footer for the deck.
HMFLAG
Defines a conduction group identification number in HyperMesh.
Change the input component of an element.
Defines a global origin for the analysis.
Gives the date and time that the deck was written and serves as a signal that the deck was created by HyperMesh.
Preserves plot element information in solvers that do not support plot elements.
Re-associate nodes/systems with their local systems.
Import comment to sort and organize entity sets into HyperMesh.
Import comment to associate support loads into a load collector in HyperMesh.
Preserves tag information in solvers that do not support tags.
Import comment to indicate to the reader that information in this section should be retained in the unsupported area of HyperMesh.
Import comment to color an entity in HyperMesh.
Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
Configure the view and behavior of Engineering Solutions.
Discover Engineering Solutions functionality with interactive tutorials.
Noise, Vibration and Harshness (NVH) is an important vehicle attribute that directly affects the customer experience.
Use Squeak and Rattle Director tool to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing tasks efficiently.
The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop height in a typical drop test by controlling the run parameters and conditions with ease.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Solver interfaces supported in Engineering Solutions.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
Setup an Optimization in Engineering Solutions.
ON THIS PAGE
HyperMesh Comments
Abaqus
Nastran
PAM-CRASH 2G
ON THIS PAGE
