Export Geometry
Export a CAD file.
  1. Import geometry in the following ways:
    • From the menu bar, click File > Export > Geometry.
    • From the Standard toolbar, click (Export Geometry).
    The Export - Geometry tab opens.
  2. For File Type, select the file type to export.
  3. In the File field, specify a filename and location.
  4. Define CAD export options by clicking to the left of Export Options.
  5. Click Export.
