Systematic Issue / Topology Optimization
- OptiStruct's design-synthesis technology uses the topology optimization approach to generate innovative concept design proposals. OptiStruct generates an optimal design proposal for the connectors layout of the design based on user-defined design space and design targets.
- In SnRD Modal Frequency Response analysis is used as the optimization load case with an objective of minimizing the modal relative displacement across the selected E-Line.
- SnRD Optimization module, automatically converts the time domain excitations to frequency domain for creating the MFREQ loadcase. Amplitude and phase are considered.
- The design variable for Topology optimization is the CBAR element connecting the Master and Slave components.
- Optimization can be done for the response at single frequency or for a band of frequencies.
Optimization Deck setup
Once the optimization deck setup is initiateed, following changes are done to the solver deck:
- Load case setup : Modal Transient (MTRAN) analysis is changed to Modal Frequency Response (MFREQ)
- Optimization parameters set-up: Responses and ConstraintsNote: Frequency range selection table will be empty for a Static Load case setup work flow.
Optimization Deck setup process
- Select interface with Squeak and/or Rattle issue.
- Load the interface to understand the critical frequencies Figure 2.
- Select direction for Optimization.Note: This selection must be based on the information shown in the Relative Displacement or Line graph.
- Identify frequency or frequencies to optimize.
- Select the Auto Fill option to automatically fill the frequency (Top Contributing mode from RMC Bar Chart) or frequencies of selected modes.
- Click file browser icon for Choose Directory option.
- Click Export button.
