SnRD Post Tab
- Model File - You can browse and select model file
.FEM
) file which was generated from Export Solver Deck - Pre-output File - CSV file containing the ELine data.
Note: The Pre-output CSV is generated automatically during the SnRD Pre processing steps. Once you completes the material mapping task, the CSV file exported to the same location as the model is present and created with the same name of the model with
_pre_output
being suffixed. The CSV file is of the following format.Figure 2.The file format contains the following columns -Column Remarks Line ID
ELine number Line Type
States the line type, Rattle or Squeak Materials pair
Mapped materials names are listed min-max
Impulse rate minimum and maximum values are listed Interface Name
Name selected for the interface and this is picked from DTS file Gap Dimension [mm]
Gap dimension between the selected interface. This value is picked from DTS file Tolerance [mm]
Tolerance limits for the gap dimension for the selected interface. This value is picked from DTS file Master ID
Master component ID for respective ELine Slave ID
Slave component ID for respective ELine Contact Type
Contact type defined for the ELine - Results File selection allows you to -
- Add add result files for processingNote: Once a result file is added the session, the respective subcase present in the file is listed in the Subcase Selection table. You have to select at-least one subcase from the list for results processing.
- Remove to remove a result file from the list
- Save Session File - to save a HyperWorks X session file. This session will be utilised to store the post processing data of SnRD.
- Analysis Type - drop down to select an anaylsis type.
Supported analysis types are -
- Rattle
- Squeak
- Line(s) to analyze - drop down to select the required ELine from the model.
- % statistical evaluation - to specify the percentage of
statistical evaluation based on the methodology implemented while studying the
squeak and rattle analysis of the model.Note:
If you specifies
0%
, the values will not be sampled and a "mean value" will not be calculated. A global maximum will be taken into consideration in this case.If you enters a value less than
0
and greater than100
, SnRD will show a warning message and will ask you to enter a value within0
and100
. - Session Type - radio button option to select the required
session type. The supported options are -
- Summary - This option creates one session per subcase with only the overview pages for each of the squeak and rattle interface in the model.
- Full Analysis - This option also creates one session per subcase, and creates detailed plots for each of the interfaces present in the model.
- Execute - after making the required selection of files, you have to click Execute to execute and evaluate the squeak and rattle issues.
- Load Session - you can also load a previously executed session file. This helps you to populate data of any previous execution.
- Collapse UI - click the collapse button
to close the Inputs selection and to view the main SnRD tabs.
