Dynamic Load Creation Tutorial
Create DLoads.
Click Dynamic from Select Subcase drop down list.
The drop down list shows the subcases created in the Subcase Creation Tutorial step.
Figure 1.All the TLoads present in the subcase will be listed in the table on the right hand side of the panel. -
Enter
3.0
as the scaling factor inDLOAD Scale Factor field. - Select the listed TLoads to use in creating a dynamic load collector.
Click Add.
A dynamic load collector is created and listed in the adjacent table.
Figure 2. - Click the radio button for the created load to activate it.
Click Next to proceed to the
next step in the process.
Note: You need to create and activate at least one load collector in this panel before moving to the next step.
