Dynamic Load Creation
In this step you can combine transient loads to create a Dynamic load. The panel for this operation is shown below.
- Select Subcase - to select the required subcase from a drop down list.
- Scale Factor - to provide a scaling factor for the dynamic load
- Constraints list table -
- All the transient loads created in the previous tasks be listed in the first table.
- Allows you to select constraint(s) to combine.
- You can use the selection options in the table.
- Select All
- Unselect All
- Reverse Selection
- Add - to create and add the DLOAD cards in the second table.
- Refresh - to refresh the table data.
- Update -to update a previously created DLOAD card
- Delete Selected and Delete All options to delete the DLOAD cards from the second table.
