Modal Damping Definition
In this step, you can create and define modal damping properties for the load steps in the model. The panel for the same is shown below.
- Global - G
- Critical - CRIT
- Quality Factor - Q
- Subcase - to select the required subcase from a drop down list.
- Select required Damping Type from the list
- Add or Delete rows in the table.
- Also, you can import CVS files for damping definition.
- Add - to create and add the TABDMP cards in the second table.
- Refresh - to refresh the table data.
- Update -to update a previously created TABDMP card
- Delete Selected and Delete All options to delete the TABDMP cards from the second table.
