Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
3D views are used to display and interact with the model. You can zoom, rotate and pan around a 3D model using the keyboard,
mouse or a combination of both. You can use a 3D mouse, specify a view or select specific parts of a model. Multiple 3D
views are supported.
Define field or current data using either far field data, near field data, spherical mode data or PCB current data. The
field/current definition is used when defining an equivalent source or a receiving antenna.
Define a medium with specific material properties, import a predefined medium from the media library or add a medium from
your model to the media library.
Defined media can be applied to the model in various ways. Some media settings are applied to regions, others on faces
and wires. The rules for defining media varies between the different solution methods.
Use a periodic boundary condition (PBC) to analyse infinite periodic structures. A typical application of PBC is to
analyse frequency selective surface (FSS) structures.
Create an arbitrary finite antenna array that consists of an array of contributing elements, either with direct feeds for
each element or via indirect coupling, and solve with the efficient domain Green's function method (DGFM).
Use the windscreen tools to define a curved reference surface constrained by a cloud of points, normals and optional U′V′ parameters. The constrained surface is then used as a reference to create a work surface where windscreen layers and curved
parameterised windscreen antenna elements can be created.
The Windscreen tab is not displayed on the ribbon by default, as it contains advanced tools related to creating windscreen antenna
elements. To access the Windscreen tab, you must configure the ribbon to show the tab.
A constrained surface is a reference surface constrained by a cloud of points, normals and optional U′V′ parameters. Use a constrained surface as a reference to create windscreen layers and curved parameterised windscreen antenna
elements.
Define curved parameterised windscreen antenna elements on a specified work surface by using surface lines, surface
Bézier curves or an array of linearly spaced lines.
Many electromagnetic compatibility and interference problems involve cables that either radiate, irradiate or cause coupling
into other cables, devices or antennas. Use the cable modelling tool and solver to analyse the coupling and radiation.
For a frequency domain result, the electromagnetic fields and currents are calculated at a single frequency or frequency
range. When the finite difference time domain (FDTD) solver is used, the frequency must be specified to convert the native time domain results to the frequency domain.
The excitation of an antenna is normally specified as a complex voltage, but it may be useful to specify the total radiated
or source power instead. The result is then scaled to yield the desired source power level.
A port is a mathematical representation of where energy can enter (source) or leave a model (sink). Use a port to
add sources and discrete loads to a model.
Obtain multiple solutions for a single model using multiple configurations. Multiple configurations remove the requirement
to create multiple models with different solution requests.
Use an infinite plane or half-space to model a ground plane efficiently. The number of triangles in the model is reduced
as the ground plane is not discretised into triangles.
During the design process, the development of a model can introduce a range of issues that can lead to a non-simulation-ready
model. Use the validation toolset to verify that the model is simulation-ready or to search, detect and flag discrepancies.
The default solver used in Feko is the method of moments (MoM) - surface equivalence principle (SEP). Whether a solver is specified per model, per face or per region, depends on the solver in question.
CADFEKO has a collection of tools that allow you to quickly validate the model, for example, perform calculations using
a calculator, measure distances, measure angles and export images.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
Defining Windscreen Elements on a Curved Work Surface
by using surface lines, surface Bézier curves or an array of linearly spaced
lines.
Figure 1. A preview of regular spaced surface lines (in green) on a curved work
surface.
Create a line in the curved work space.
On the Windscreen tab, in the
Create surface curve group, click the Surface line icon.
Specify the Start corner point, End
point and Work surface.
Click Create to create the surface line
and close the dialog.
Create a surface Bézier curve in the curved workspace.
Create surface curve group, click the Surface Bézier curve icon.
Specify the Start point, Start
tangent point, End tangent point,
End point and Work
surface.
Click Create to create the surface Bézier
curve and close the dialog.
Create an array of linearly-spaced lines in the curved workspace.
Create surface curve group, click the Surface regular lines icon.
Specify the Constant parameter, Start
corner point, End corner point,
Spacing and the Work
surface.
Click Create to create the regular spaced
surface lines and close the dialog.
