Advanced Settings for Cable Types
Use an advanced setting to specify the cable per-unit-length parameters accuracy.
Use CADFEKO to configure a solver-ready input file for Solver simulations.
View the main elements and terminology in the CADFEKO application window.
CADFEKO has various default settings that you can configure to customise it to your preference.
Store the unmeshed CADFEKO model and calculation requests to a .cfx file to reopen later.
3D views are used to display and interact with the model. You can zoom, rotate and pan around a 3D model using the keyboard, mouse or a combination of both. You can use a 3D mouse, specify a view or select specific parts of a model. Multiple 3D views are supported.
Define the model unit, variables, named points, workplanes and the model extents for the model.
Create fully parametric and complex CAD geometry using canonical structures and perform Boolean operations on these.
The component library contains an extensive list of common components, such as antennas and platforms.
An assembly is a tool that is used to organise geometry and mesh parts. It allows you to group the geometry or mesh parts in the model tree.
Mesh parts can be manipulated in CADFEKO. Basic mesh editing and fixing capabilities allow triangles to be added, removed and mesh parts to be merged.
Import a CAD (geometry) model or mesh model from a wide range of industry formats into CADFEKO to save time and development costs.
A CADFEKO model can be exported to a variety of industry standard geometry and mesh formats to be used in other applications.
Define field or current data using either far field data, near field data, spherical mode data or PCB current data. The field/current definition is used when defining an equivalent source or a receiving antenna.
Define a medium with specific material properties, import a predefined medium from the media library or add a medium from your model to the media library.
Defined media can be applied to the model in various ways. Some media settings are applied to regions, others on faces and wires. The rules for defining media varies between the different solution methods.
Use a periodic boundary condition (PBC) to analyse infinite periodic structures. A typical application of PBC is to analyse frequency selective surface (FSS) structures.
Create an arbitrary finite antenna array that consists of an array of contributing elements, either with direct feeds for each element or via indirect coupling, and solve with the efficient domain Green's function method (DGFM).
Use the windscreen tools to define a curved reference surface constrained by a cloud of points, normals and optional U′V′ parameters. The constrained surface is then used as a reference to create a work surface where windscreen layers and curved parameterised windscreen antenna elements can be created.
Many electromagnetic compatibility and interference problems involve cables that either radiate, irradiate or cause coupling into other cables, devices or antennas. Use the cable modelling tool and solver to analyse the coupling and radiation.
The general process is explained for setting up a complete cable analysis.
The Cables tab on the ribbon contains advanced tools related to defining cable harnesses.
Cable harnesses are becoming increasingly complex with innovations in the automotive industry. Import a complex cable harness from a .kbl file using the “harness description list” (KBL) specification.
A comprehensive range of cable types is supported for cable analysis.
A single conductor consists of a core with an optional outer coating.
Feko has an internal coaxial cable database that contains more than 20 popular coaxial cable types from industry.
A coaxial cable can be characterised by its characteristic impedance and propagation constant.
A coaxial cable consists of a core with outer insulating layers and a shield.
A ribbon cable consists of multiple cores with an optional coating for each core.
A twisted pair consists of two cores that are twisted together for the purposes of cancelling electromagnetic interference. Each core can have an optional coating.
A cable bundle may consist of multiple defined cables (for example, single conductors, coaxial cables, ribbon cables, twisted pairs, other cable bundles and non-conducting elements) that are embedded in a medium with an optional shield.
A non-conducting element consists of a fibre core.
A cable shield is a conductive layer that encloses a cable to reduce electromagnetic interference (EMI) and crosstalk to other cables.
A cable path is a defined route along which cables are installed and specified as a series of straight lines.
A cable connector is the end terminal for a cable.
A cable instance is a single cable (for example, ribbon, cable bundle, coaxial cable) with its cable connectors that is routed along a cable path.
A cable harness is a collection of cable instances routed along a cable path with a solution method specified for the outer conductor.
For a complex cable harness, it is not a simple task to find a specific cable instance in the 3D view. Use the “Find cable” tool to locate a cable instance.
After a harness description list is imported, it may be necessary to convert multiple single conductor cables into a new type of cable.
All tubes in a harness can be randomly located and packed using the “Rearrange cross sections” tool.
The cable schematic view allows you to add cable ports, complex loads, resistors, capacitors, inductors, external SPICE circuits, general networks (defined using N-port Touchstone files) and probes to a specific cable harness as well as connecting cables to one another.
For a frequency domain result, the electromagnetic fields and currents are calculated at a single frequency or frequency range. When the finite difference time domain (FDTD) solver is used, the frequency must be specified to convert the native time domain results to the frequency domain.
The excitation of an antenna is normally specified as a complex voltage, but it may be useful to specify the total radiated or source power instead. The result is then scaled to yield the desired source power level.
A port is a mathematical representation of where energy can enter (source) or leave a model (sink). Use a port to add sources and discrete loads to a model.
A source is used to excite or illuminate the model and cause current to flow.
Complex feed networks can be simplified by including them as a circuit representation using general network blocks.
Obtain multiple solutions for a single model using multiple configurations. Multiple configurations remove the requirement to create multiple models with different solution requests.
Before running the Solver, define the output requests.
Use an infinite plane or half-space to model a ground plane efficiently. The number of triangles in the model is reduced as the ground plane is not discretised into triangles.
During the design process, the development of a model can introduce a range of issues that can lead to a non-simulation-ready model. Use the validation toolset to verify that the model is simulation-ready or to search, detect and flag discrepancies.
The default solver used in Feko is the method of moments (MoM) - surface equivalence principle (SEP). Whether a solver is specified per model, per face or per region, depends on the solver in question.
Specify the command-line parameters for the Feko components.
CADFEKO has a collection of tools that allow you to quickly validate the model, for example, perform calculations using a calculator, measure distances, measure angles and export images.
View the icons that are found in the model tree.
View the icons that are found in the details tree.
View the files associated and generated by CADFEKO.
