RL-GO Ray Launching Settings
A number of ray launching geometrical optics (RL-GO) settings are available.
On the Solve/Run tab, in the
Solution settings group, click the Solver settings icon.
On the Solver settings dialog, click the High
frequency tab.
- Adaptive ray launching settings
- This option allows you to control the density of the rays launched, as well as when to stop
tracing a ray based on the ray's decay.
- High (more rays): The ray density is high. Results take longer to obtain but with higher accuracy.
- Normal (default): The default ray density setting.
- Low (fewer rays): The ray density is low. Results are fast to
obtain but with lower accuracy.Note: Start with Low (fewer rays) which uses the least computational resources. When the model appears to be performing as expected, use a higher setting.
- Fixed grid increments
- This option allows you to specify the ϕ and θ
angular resolution for ray launching and the increments for the parallel ray front in the
U direction and V direction. Though the run-time for a
problem involving RL-GO may be decreased using this option,
it may influence the accuracy of the solution.Note: Manual specification of the angular increment should only be used under specific conditions after the implications have been carefully considered.
