Creating a Wire Port (Mesh)
Apply a wire port directly on a mesh segment or vertex (imported mesh or an unlinked mesh).
On the Source/Load tab, in the
Ports group, click the
Wire port icon.
Figure 1. The Create wire port (mesh) dialog. - Specify the mesh segment where the port is to be placed.
In the Segment field, use point entry to specify the
mesh segment using one of the following workflows:
- In the 3D view, click on the relevant mesh segment.
- In the details tree, click on the relevant mesh segment.
Specify whether the port is to be placed on a mesh segment or a vertex.
- To add the wire port to a segment, select Segment.
- To add the wire port to a vertex between two segments, select Vertex.
- [Optional] If the polarity of the port is to be reversed, select the Reverse polarity check box.
- Click Create to create the wire port and to close the dialog.
- In the Label field, add a unique label for the wire port.
- Click the Create button to create the wire port and close the dialog.
