Editing Mesh
It is not possible to edit a simulation mesh directly, but you can unlink the simulation mesh and edit the mesh part as though it is an imported mesh.
- Select the geometry part or mesh part in the model tree (the part should have a simulation mesh).
Unlink the simulation mesh using one of the following workflows:
- From the right-click context menu, click Unlink mesh.
- On the Mesh tab, in the
Simulation mesh group, click the
Unlink mesh icon.
From the drop-down list, select one of the following unlink
methods:
- To unlink the mesh and use new ports, click
and use new ports.
- To unlink the mesh and use existing ports, click
and use existing ports.
